Stumped on Lsvtec oil pressure
Old Jan 20, 2022 | 09:39 PM
thetegman's Avatar
Default Stumped on Lsvtec oil pressure
Alright so I have a built b-ls with a itr head and the whole shabang. When I first put the motor in and primed it, after first startup oil pressure was pretty good. around 10 psi @700-800 rpms. During break in and currently, I am having low oil pressure around idle, but within spec through the rpm range. Cold start pressure is fine, but when its fully warmed up and hot at 1k rpms oil pressure sits around 4-5 psi, and 9-10 at most. Sometimes at 1500 rpms when i lock the idle there oil pressure will be between 14-11 psi. Cant seem to figure out why, I have an idea, but I dont think it would affect pressure that much, as I believe the plug on the bottom of the head is leaking, as well as the distributor. I dont want to just rule that out but I need advice. switched to 10w-40 a while ago and it brought it up by 2psi. Anyone have any ideas? any insight is greatly appreciated
Old Jan 21, 2022 | 09:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Stumped on Lsvtec oil pressure
What brand of main bearings did you use ?
Old Jan 22, 2022 | 02:31 PM
thetegman's Avatar
King enginesbearings
Old Jan 22, 2022 | 02:33 PM
thetegman's Avatar
i also dont want to not think its the bearings, because of the leaks i have. anyone?
Old Jan 22, 2022 | 09:10 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Top end leaks do NOT affect bottom end oil pressures... just because you don't like the answers doesn't mean they don't have merit. You used questionable bearings for your application. You must consider it.
superspadez
Jan 26, 2015 08:35 AM
dragvixen
Jul 10, 2009 11:20 AM
steveharrmr23
Aug 7, 2008 10:52 AM
nevaeh_bebe
Mar 25, 2008 05:09 PM
hondaeg8
Feb 3, 2004 01:05 PM
