Replaced ECU, now have MAP sensor fault
Old Jan 19, 2022 | 12:48 PM
4g4dcruisin's Avatar
Default Replaced ECU, now have MAP sensor fault
96 civic 5 speed.
EDIT: Reset the ECU and the CEL went away. I’ll see if it returns.
The ECU since I had the car has been faulty. The fuel pump wouldn’t always prime. So I swapped it out for a “known good ECU.”
plugged in the new ECU, fuel pump primes no issue and fires right up.
BUT, now I have a CEL for P0108 MAP High pressure. The old ECU never gave me a code. I unplugged the MAP while the car was on and it made the idle bounce so I know the MAP sensor is “working.”
Not sure what to do. Both ECUs are P2E rev L01.
angryporto
Engine Management and Tuning
Aug 9, 2020 10:47 AM
boostedcivicsir
Jul 24, 2007 11:49 AM
.brad
Jan 21, 2002 02:01 PM
