Wipers stopped in upright position.
Old Jan 18, 2022 | 07:42 PM
Regaan's Avatar
Icon4 Wipers stopped in upright position.
Hi, got a problem, my 2016 Civic EX wipers stopped working. They both now point directly up, and I have to manually push them down. Flicking the stem into each wiper speed position no longer works and the wipers do not move at all* (*See #4)
  1. Checked fuse and appears to be good.
  2. No noise coming from the motor when flicking the stem up.
  3. Both arms move together when I manually move the arms, so I don't believe it's the transmission.
  4. If I disconnect and reconnect the battery, reset the arms to standard parking position and flick the stem they'll move across the windshield and then stop when pointing directly up again.
Appreciate any help.
Old Jan 19, 2022 | 04:45 AM
hondamark35's Avatar
Default Re: Wipers stopped in upright position.
I haven't seen it happen on a factory original wiper transmission/linkage, but after market replacements can slip at the crank coming from the motor. the stop position is usually internal to the motor housing.
Best suggestion I have is to pull to cover and see what's happening when it moves and stops.
kmaz93da
Apr 18, 2010 11:06 AM
Powered By Garrett
Mar 30, 2008 08:45 AM
Newfie
Honda Civic (2001 - 2005)
Apr 18, 2007 09:20 PM
Mjfan12
Jul 11, 2006 04:41 PM
Rhythm Racer
12
Apr 20, 2005 12:56 PM
