Code 16 civic 95
The car go 3 cylinderFail n4
All injectors has good resistence, All wires has 12+,
I changed injectors ,I changed n4 wires by n3 wires , I changed ecu hondata for stock, i changed spark plug
New coil, spark plugs wires, rotor, tape, The n3 main relay has 12+, I need help!!
The valve seat damage wouldn't create the code... but it will create a dead cylinder, making the engine sound like a Subaru... sending you down the path of searching for an answer. It could simply be a code set by unplugging fuel injectors while the engine was idling to see which cylinder is missing.
rino924
Dec 28, 2006 08:32 AM
civickid99
May 8, 2004 12:15 PM
shivic
Jan 4, 2004 04:36 PM
