1992 Civic VX Wiper Switch Replacement
My wiper switch on the right side of the steering wheel has gone kinda floppy. I want to replace it with one that works properly, but the specific part number for my vehicle is discontinued and sold out everywhere I've looked. Can I use the switch from the same year Civic sedan? The connections all look identical, and the actual part looks identical. Think I should buy one and try it out?
You likely can use the wiper switch from a different trim level. Depending on what's wrong with the switch, you might be able to just open it up and fix the switch.
See these threads:
https://honda-tech.com/forums/honda-...ences-3309373/
Fix your EG Wiperswitch
See these threads:
Get a stalk from any trim level Coupe or Sedan and then you don't have to worry about finding a hatch switch without a rear wiper control.
92-95 is your target.
Any 92-95 or 96-00 Civic. However, you get one from them and you get INT wipers, so to make that feature function you gotta grab the ICU (behind the fuse box). Check my sig for other upgrade mods re: wiper switches and ICUs.
SR20 Inside
Jan 25, 2006 09:24 PM
couter
Jan 15, 2006 02:17 PM
