Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Spark Plug Tube seal issue
Old Jan 16, 2022 | 06:24 AM
ridgeline's Avatar
Default Spark Plug Tube seal issue
I have a 2008 Honda Ridgeline and did a valve adjustment and wanted to replace the gaskets while I was there. The problem is that the tube seals that come with the gasket set do not fit and I am told by the parts store there is no other option. I have done my internet research and have found the problem to be the type of valve cover on my Ridgeline is different. The walls of the tube seal holes in the valve cover have a ridge. The walls are not flat. All of the videos and pictures I have found show the walls to be flat, which would allow these tube seals to work. Unfortunately that is not the valve covers on my vehicle and I am stuck. Not sure where to get the seals I need for these valve covers. The VIN says I have the J35A9 engine if that means anything to you tech experts. I have seen one photo of a valve cover that has a ridge on the wall on the internet that looks like mine but it was on an earlier year model Accord. I am hoping someone else can help me sort through this unique situation because right now I am not sure where to go next.
Old Jan 16, 2022 | 07:27 AM
Ryanthegreat1's Avatar
Default Re: Spark Plug Tube seal issue
Have a picture of what you are seeing? That is odd.
Old Jan 16, 2022 | 11:18 AM
ridgeline's Avatar
This shows the valve cover
This shows the ridge.
Old Jan 16, 2022 | 01:16 PM
That looks to me like the steel ring inside the seal is still present. Is that inner ring magnetic?
Old Jan 16, 2022 | 02:20 PM
ridgeline's Avatar
Yes it is magnetic. Wow! I never considered that. It is so tight it feels like it is part of the valve cover. Obviously it’s not aluminum. I guess it is ok to start pounding on it.
thank you for your insight
Old Jan 16, 2022 | 03:30 PM
Those seals can be VERY stuck. Usually my full body weight on a tire spoon to get them to pop.
Just me
Dec 20, 2008 04:16 PM
old_school_dohcvtec
Jul 21, 2007 10:54 AM
standbackimapro
Apr 29, 2006 05:38 PM
Jeff
Oct 10, 2005 09:54 PM
blackflag188
Nov 9, 2004 04:54 PM
