Honda CR-V & Element 2WD & 4WD Element & CR-V
2017 Cr V O2 sensor replacement
Old Jan 15, 2022 | 04:32 AM
Swiftie51's Avatar
Default 2017 Cr V O2 sensor replacement
Hi, am trying to replace o2 sensor (pre cat) on 2017 Cr V 1.6 diesel. oem is 5 wire and would like to know if i can fit 4 wire sensor instead and if so how to connect wires as they are different colours?New Sensor 2 white wire 1 grey and 1 black, 5 wire colours 1 grey 1 black 1 white 1 yellow and 1 red. fault code is P2A00.
Old Jan 15, 2022 | 06:24 AM
Ryanthegreat1's Avatar
Default Re: 2017 Cr V O2 sensor replacement
5 wire is probably a wide band sensor where a 4 wire is a narrow band sensor. They are not compatible in any way.
You will need to find the correct sensor.
Mugen112
Oct 31, 2006 08:22 PM
xmd
Oct 12, 2003 10:38 AM
Slow96RedEk
May 16, 2003 08:10 PM
Pele
Oct 11, 2002 10:57 PM
