Finally am able to start working on my 89 hatch si
Old Jan 12, 2022 | 04:06 PM
89effs's Avatar
Default Finally am able to start working on my 89 hatch si
I was an active member during the days of the Griffith park meets you guys helped me out a lot when I was broke teenager and needed help fixing my car. I had to put my car aside and get something a little more family-friendly but now I'm able to spend the time needed to restore this to an acceptable level.
I'm currently in the process of buying the parts needed to restore the fuel and brake system. I have purchased a obd2 zc engine and will change the water pump timing belt and a few other things before installing. I will be running obd 1 on the car.
​​​​​I am also the process of buying interior parts that have been cracked and damaged over the years that I have left it out in the sun and there is a lot of damage. I had the stock seats with the red pinstriping on it but they are severely damaged /ripped. I can't decide whether I want to try to reupholster the original seats or get some aftermarket seats.
As for the exterior the car was involved in a few minor accidents and the front of the car needs a lot of work.
By any chance do you guys know the original paint name/code for the white Civic SI? I would like to repaint it the same color when I find it.
Any input or suggestions are appreciated thanks.
Old Jan 12, 2022 | 04:19 PM
Efmysedan's Avatar
Default Re: Finally am able to start working on my 89 hatch si
Input
Plans to run obd1 on a obd2 motor
never gonna run
Old Jan 12, 2022 | 04:20 PM
Efmysedan's Avatar
Suggestions run obd2
Old Jan 12, 2022 | 04:28 PM
89effs's Avatar
I will be running all OBD1 components on the engine (including motor mounts), I was searching through archives and thought it would work this way. Is this not correct?
The previous engine was already converted to OBD1.
Old Jan 13, 2022 | 03:50 AM
Efmysedan's Avatar
Not correct
swap to obd1 cylinder head
Old Jan 13, 2022 | 06:05 AM
kraquepype's Avatar
10 Year Member
Good luck with it! I can get you the paint code from mine later since its the same car.
You can run an OBD2 engine fine on OBD1, but you will need adapters for the distributor and alternator, or OBD1 dist/alt to replace them with.
Old Jan 13, 2022 | 11:00 AM
Maxcapacity's Avatar
The paint code is normally on a sticker in the driver's door jam near the catch. Should have 2 or 3 letters and numbers
Old Jan 13, 2022 | 12:17 PM
niko2020's Avatar
Interior parts and trims are becoming harder to come by. I’m in the process of restoring my 88 civic hatch. I wish I could say junk yard is your best bet but not anymore. You might still find a few here and there but most are going to be stripped away anyway. eBay is your best bet but expect to pay premium. I recommend coverking for the seats though. They are reasonably priced and have many options for you to choose from. Good luck and have fun with it.
Steam Driver
Sep 11, 2021 10:38 AM
TNRG_AXIOS
Mar 3, 2020 04:38 PM
JoeSelf
Texas -OK -LA (Sales)
10
Jul 20, 2011 01:13 PM
thowes24
Honda Civic (2006 - 2015)
55
Jan 17, 2010 04:01 PM
95turbodteg
Feb 7, 2008 01:21 PM
