ABS Light on after B18c Swap, EG hatch
Hey guys
Swapped a 1996 spec B18c2 into my 1992 EG hatchback
Now my problem is, after swapping my motor in I have a lingering Engine light in the car that is the last thing I need to sort out. So far I've tried replacing all the ABS fuses located under the hood and cleaning the sensors on the front suspension
During the swap I also replaced the driveshafts, Lower ball joints and of course the motor, As well as swapping the factory OBD2 P72 ecu supplied with the motor for a OBD1 P72 chipped with a Hondata S300
Could anyone suggest the next steps I should take or even have a solution as to how to fix this? I've reached the full extent of my knowledge
phateless
Nov 28, 2005 07:40 AM
