Motor Swap Help Again…
Just recently picked up a 98’ Integra motor to swap into my 00 hatch while my other motor is being built, so I’ve got a few questions for what can be used.
So I know the motor I just got is obd2a and my car is obd2B I also have an obd2B manual Integra ecu and a manual 99-01 crv harness which I know will work for the built motor being it’s OBD2B.
Im wondering what harness can I use, thinking a obd2a civic harness (non vtec) and cutting up that one to make it work if it’s possible and then using a jumper harness to the ecu and dizzy if needed ? I’ve got everything else to finish the swap just the wiring confused me and I haven’t seen anyone throw an obd2a motor in a car that’s obd2B and not have a completely confusing write up on it
Keep the engine harness that matches the car. I would just run jumpers where necessary. You can contact Mono Pena (MonoTech) on FB and he can make you the jumpers you need.
