d15b motor swap
d15b motor swap
hey im doing a d15b motor swap into a 92 civic hatch im getting the motor from hmotorsonline my questions is is it a direct bolt into?
were do i get a p28 ecu from and wiring harness?
thanks
thanks
Re: d15b motor swap (mtownsi)
wich harness can i use that will plug rite into to everything? and the motor is jdm so is the wiring harness gonna be on the opposite side?
the kid before me put a d16z6 in but its all chopped up he had an ls ecu running and ran the vtec to a toggle switch its a wiring nightmare so i wanted to start over.
oh i also did a compression test today #1 cylinder was 120psi #2 cylinder was 110psi #3 cylinder the kid stripped the spark plug into so i couldnt get it out it dont even tighten up it just keeps spinning. and #4 cylinder the spark plug was totally covered in oil and it had 125psi
Re: d15b motor swap (ieatrice)
Don't mean to jack your thread but I have a similar question. I'm putting a d15b in my 96 hatch. Is this is a direct bolt in for me also (specifically motor mounts)and also I know i will have to convert to obd1 so what harness will i need.
streetcartuner
18
02-18-2008 02:15 PM
hatchblack
01-01-2004 08:04 PM
LD_EGSICK
01-26-2003 06:42 PM
