Compression drops with VTEC Head LS Block (Turbo)?
Old Jan 3, 2022 | 02:00 PM
Clean.EK's Avatar
Icon5 Compression drops with VTEC Head LS Block (Turbo)?
Hi, I will attempting a budget LS Vtec Turbo build with B18B Block
I was considering using Nippon Turbo Pistons and I noticed the loss of compression when used with B18c head.
Nippon states Turbo Pistons result:
  • B18A/B Block and Head 9.23:1
  • B18A/B Block with B18C1 Head 8.74:1
But if you attempt LS VTEC on stock motor, the compression is always higher when using VTEC head but in this case it loses compression with VTEC Head, is that a typo?
Old Jan 3, 2022 | 06:44 PM
Ryanthegreat1's Avatar
Default Re: Compression drops with VTEC Head LS Block (Turbo)?
The vtec heads do have a smaller combustion chamber so it should net a higher compression ratio on the same piston.
Maybe they have two different part numbers? VTEC heads might need a bigger valve pocket in the piston?
If they are the same piston for both applications then the marketing team messed up.
Old Jan 4, 2022 | 02:41 AM
ls joker's Avatar
Loved
Use the zeal calculator and plug in the specs
Old Jan 4, 2022 | 03:52 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Vtec head should have the higher compression of the 2
Old Jan 4, 2022 | 09:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Always, regardless of which VTEC head you use.
Old Jan 6, 2022 | 01:54 PM
highschooler's Avatar
Do the pistons have two different part numbers?There might be a piston meant for the B18B, and one meant for the LS/VTEC which would explain the difference in compression ratio.
If they are the same part number then I’m not sure what to think.
Also, if you are going turbo, I really think it’s worth it to spend the few hundred extra $ on better pistons than Nippon. Nippon are stock replacement. Unless you plan to never go over about 275hp, then you’ll be alright with Nippon.
Old Jan 6, 2022 | 01:57 PM
We’ll it says they are good to 450hp, but that’s still a lot lower than other aftermarket pistons.
1996Civic_CX
Sep 1, 2008 07:56 AM
219DAdriver
Feb 17, 2008 02:45 PM
MugenGSRb18
Sep 7, 2004 12:43 AM
fuguman
Sep 16, 2002 12:14 PM
