Compression drops with VTEC Head LS Block (Turbo)?
Hi, I will attempting a budget LS Vtec Turbo build with B18B Block
I was considering using Nippon Turbo Pistons and I noticed the loss of compression when used with B18c head.
Nippon states Turbo Pistons result:
- B18A/B Block and Head 9.23:1
- B18A/B Block with B18C1 Head 8.74:1
The vtec heads do have a smaller combustion chamber so it should net a higher compression ratio on the same piston.
Maybe they have two different part numbers? VTEC heads might need a bigger valve pocket in the piston?
If they are the same piston for both applications then the marketing team messed up.
If they are the same part number then I’m not sure what to think.
Also, if you are going turbo, I really think it’s worth it to spend the few hundred extra $ on better pistons than Nippon. Nippon are stock replacement. Unless you plan to never go over about 275hp, then you’ll be alright with Nippon.
