Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Correctly adjusting timing gear.
Old Jan 2, 2022 | 06:24 PM
Jonathan Perch's Avatar
Default Correctly adjusting timing gear.
I’ve recently put Kpro and a hondata d17 timing care in my car. Be timing was off before the swap. Corrected it after I put in the ecu and cam gear. But my car still has no power. I put the cam gear at 0 degrees, but still nothing. Any ideas that might fix my problem???
Old Jan 2, 2022 | 08:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Correctly adjusting timing gear.
Well, you either still have the engine out of mechanical timing OR the calibration that you are using is WAY off making the engine perform poorly.
eg6BT
Oct 2, 2006 07:59 PM
ek4__
Aug 3, 2006 08:15 PM
downeyballz
Jun 6, 2005 04:34 PM
