2000 accord cel check
Old Nov 17, 2002 | 01:57 PM
d8168055's Avatar
Default 2000 accord cel check
where is it? the blue connector, for the paperclip trick... thanks... pls dont ask me to do a search... i cant find it
Old Nov 17, 2002 | 02:58 PM
iam7head's Avatar
Default Re: 2000 accord cel check (d8168055)
someone show it how to me once..
i did it long time ago..
1) locate the blue connector(you should see two blue connectors, the deeper, harder to reach one is it)
(is located at the left of the clutch..)
2)use a paperclip and stick it in the Male connector.(your car is turn to OFF)
3)turn car on..and it should flash..you need to remove it like in 10 second
and stick it back it again..and it will flash.
4)you need to do it like three time and it will turn off by itself..
the flash is special so you would miss it.
sorry..I kinda forgot some of the steps...
maybe some accordian should chime in..
Old Nov 17, 2002 | 03:21 PM
Chiovnidca's Avatar
Nope, no blue connector on those. You have to jump pin 9 to ground on the data link connector. (It's the brown wire.)
Old Nov 17, 2002 | 03:39 PM
d8168055's Avatar
Default Re: 2000 accord cel check (Chiovnidca)
is it posslible to do it myself?
Old Nov 17, 2002 | 03:49 PM
Chiovnidca's Avatar
It's not hard. just jump pin 9 to ground and count the CEL blinks. A long blink = 10, a short blink = 1.
Old Nov 17, 2002 | 04:12 PM
d8168055's Avatar
do you have a pic? where is it located? i already reset the computer tho... the CEL is gone... but just for future references... just in case it comes on again...
Old Nov 17, 2002 | 04:31 PM
Chiovnidca's Avatar
Under the left side of the dash above the hood release. It's a grey 16 pin connector.
Old Nov 17, 2002 | 06:15 PM
jweller's Avatar
click here
edit: i was apparently typing with mittens on.
[Modified by jweller, 10:17 PM 11/17/2002]
Old Nov 18, 2002 | 04:41 AM
Stew Pidasso's Avatar
Default Re: 2000 accord cel check (jweller)
This wonderful post will guide you... https://honda-tech.com/zerothread?id=163761
flashcad68
Sep 1, 2021 11:42 AM
ksmAccord
Aug 8, 2014 10:29 AM
bloomin
May 17, 2013 05:04 PM
noltian
Jun 4, 2011 08:59 AM
jDubb11
Mar 21, 2006 07:46 PM
