81.5 mm lsvtec stc predator 600 hp turbo build thread
Old Dec 28, 2021 | 02:25 AM
nixstix01's Avatar
Default 81.5 mm lsvtec stc predator 600 hp turbo build thread
nixstix01 , 12-27-2021 08:50 PM
Hey guys been wanting to put this together for a little while learned a lot from this forum and would love to give back a little. I wanted to do all the work myself but live in a city in a building. Don t have the space to do work on my own. So a local shop is building for me. And they have been good thus far
So here pics of my setup.it’s not finished yet I have acouple more things to do but the engine is together
I know I could have done it cheaper. But I wanted the bay to look cleaned up. And I’m a little ocd about my cars lol. Also want to go awd soon but need to save more money for that. And that’s also why I’m not fully building this transmission.
I’m gonna be doing a lot of highway driving 40 rolls. I rally want to find some half mile events or roll racing events near me.
High hp css b18b block bored decked honed jet washed o-ringed and micro polished Balanced rotating assembly
All threads chased
Wiseco pistons upgraded wrist pins for going over 600 hp
Speedfactory rods
Standard acl race rod and main bearings
4 piston oil pump
Gates racing gsr water pump
Fel pro oil pan gasket
Fel pro rear main seal
Comp twin disc
Speed factory catch can
Hasport Motor mounts
Truehart solid billet tourque mounts
HEAD B16
B16 head resurfaced hot tanked cleaned new valve guides
Gsc 91lb dual valve springs and retainers
Ferrea 6000 valves and valve locks
Kelford 176 t camshafts
Gsc cam bolts with titanium washer
Golden eagle cam gears
Golden eagle oem head gasket
Golden eagle lsvtec kit
ARP 2000 head studs
Speedfactory thermal intake mani gasket
Gates racing timing belt
Edelbrock victor x intake mani
Speedfactory 70 mm throttle body
SUSPENSION/BRAKES/WHEELS/TIRES
Rear disc brake swap
Scare bird rear disc conversion bracket
Moog trailing arm bushings
Energy suspension control arm bushings
Front upper and lower and rear lower
Oem ac Delco remanufactured rear calipers
Powerstop pads
Drilled slotted rotors front and back
True hart toe arms
True hart upper control arms with upper bal joint and rear upper control arm
Progress cs2 coilovers 450/350
Timken wheel bearings front
Moog inner and outer tie rods
Moog lower ball joints
Beck and arnley e break cables
Russels ss caliper brake lines
Stash auto brake line tuck kit
Type r master cylinder and brake booster
Vms revolver 15x8 wheels
Tri state motor sport traction bar
Fuel/E85
Jb tuned 8 an feed 6 an return kit
Jb tuned oem hanger mod kit
Walboro 535 hellcat pump
I’d 2000 cc injectors
E85 freaks fuel filter
Speed factory fuel rail
Turbo/cooling
Speed trap consulting predator turbo with high temp ceramic coated turbine and compressor covers
Tri state Motorsport ramhorn
Turbo smart kompact dual port 34 mm bov
Turbo smart gen v 45 mm hyper gate
Speed factory 850 hp dual back door intercooler
All fittings oil and water lines from b and r fittings
Vibrant polished aluminum 3 inch intercooler piping
Skunk 2 dual core half radiator
spal fan
Turbosmart 4 port boost solenoid
Speed factory 4 bar map sensor
Ignition ECU
p28
Hondata s300 v3
Pwm kit for boost by gear
Honda rules coil on plug kit
Oem k20 coils
speed factory cop plate
Speed factory block off plate for distributor
TRANSMISSION
Gsr
M factory lsd
Carbon synchros
New bearings and seals
Drive shaft shop 5.9 axles
Competition clutch twin disc
Speed factory detent springs
Old Dec 28, 2021 | 07:00 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: 81.5 mm lsvtec stc predator 600 hp turbo build thread
Man that’s a heck of a build you have going! I’m headed to bed now but will be chiming in to see how things go. What level power are you going for anyway?
Old Dec 29, 2021 | 05:46 AM
nixstix01's Avatar
I am shooting for anywhere between 550 and 650 I spoke with someone who was pushing 680 with this turbo granted he had a 2.0 liter b series.
Old Dec 29, 2021 | 09:26 AM
highschooler's Avatar
The car looks good. I have a black coupe in the same body.
The parts list looks good also. The thing that stands out to me is Wiseco pistons. I was told by Wiseco that their D series pistons are rated to 600WHP. I’m not sure if that’s the point the break or that’s the point they can reliably make. However the B series ones might have a higher capacity since they are larger. Did you go with Wiseco’s upgraded wrist pins? Hopefully you did. Do you know if the Wiseco pistons you have are rated to handle the horsepower you want to achieve?
Old Dec 29, 2021 | 09:54 AM
nixstix01's Avatar
hey man sorry forgot to mention that I do have the upgraded wrist pins. I did read about the wrist pin failures above 600 after I bought them. Lol
Old Dec 29, 2021 | 10:15 AM
ls joker's Avatar
Loved
Not a bad way how to spend about thirty thousand dollars. As stated, everything looks good. Hopefully you have a shop that is skilled enough to match that quality parts list. And yes i would upgrade, or atleast start entertaining the ideal of upgraded wrist pins 500whp.
Old Dec 29, 2021 | 10:31 AM
nixstix01's Avatar
I know I could have done it cheaper but I never do anything nice for myself. I could have bought a brand new car literally but the heart wants what it wants. And the shop seems good so far we’ll see when I get the car back. Fingers crossed I should have the car in the next month if everything goes smoothly.
Old Dec 29, 2021 | 11:05 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
At thins point I think the speedfactory rods will be the weak point, I figure they are rated 700-800hp range?
Old Dec 29, 2021 | 12:15 PM
nixstix01's Avatar
their websites says rated 900 hp I don’t know if they will handle that much though
Old Dec 29, 2021 | 05:36 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
they are like the rest of the H beam rods like skunk2 or Manley. I’ve seen 900 on them, I just would not stand to close. Lol
Old Dec 30, 2021 | 02:43 AM
ls joker's Avatar
Loved
Keep it 600whp and under. Or upgrade to i beams( turbo tuff rods )
Old Dec 30, 2021 | 07:59 AM
nixstix01's Avatar
Lol it’s funny I bought the pistons and rods when I only wanted like 450 500 hp but my power goals changed as I was building so many times. the wisecos with the upgraded pins I read somwhere should be good for over 900 hp someone who works for wiseco stated this to this person and speed factory rates their rods for 900 hp the turbo is only capable of maybe 680 if I throw lots of psi 30+ lbs at it so I should be good.
Old Dec 30, 2021 | 08:12 AM
You should consider a larger capacity oil pan such as Moroso. The way Pauter explained it to me is that the stock oil pan is only good for a stock redline, but if you increase RPMs, then it’s better to have more oil capacity so that not all of the oil is stuck in the cylinder head draining back to the pan, there is enough oil in the pan to supply the block at all times.
Old Dec 31, 2021 | 08:34 AM
nixstix01's Avatar
I really want to wait till the car is back in my possession and to see what I start to do with it. Weather it be just backroad driving ,or highway pulls maybe throwing down some hot laps at a track. but for now I think staying with the stock oil pan seems the best route right now. But will be considered for the future.
Old Jan 16, 2022 | 01:56 AM
nixstix01's Avatar
Just wanted to add a pic of the rims and tires they just got mounted and balanced on the rims
tire toyo r888r on 15x8 et 20
nixstix01
Dec 27, 2021 11:50 AM
civicboy07
Oct 21, 2014 05:44 AM
runs11's
Nov 4, 2011 06:45 PM
runs11's
Oct 12, 2010 11:44 AM
craiger
May 6, 2008 04:50 PM
