600+ Hp 81.5 lsvtec turbo build
Old Dec 27, 2021 | 11:50 AM
nixstix01's Avatar
Default 600+ Hp 81.5 lsvtec stc predator turbo build
Hey guys been wanting to put this together for a little while learned a lot from this forum and would love to give back a little. I wanted to do all the work myself but live in an city. Don t have the space to do work on my own. So a local shop is building for me. And they have been good thus far
So here pics of my setup.it’s not finished yet I have acouple more things to do but the engine is together
I know I could have done it cheaper. But I wanted the bay to look cleaned up. And I’m a little ocd about stuff pertaining to my cars
High hp css b18b block bored decked honed jet washed o-ringed and micro polished Balanced rotating assembly
All threads chased
Wiseco pistons
Speedfactory rods
Standard acl race rod and main bearings
4 piston oil pump
Gates racing gsr water pump
Fel pro oil pan gasket
Fel pro rear main seal
Comp twin disc
Speed factory catch can
Hasport Motor mounts
Truehart solid billet tourque mounts
HEAD B16
B16 head resurfaced hot tanked cleaned new valve guides
Gsc 91lb dual valve springs and retainers
Ferrea 6000 valves and valve locks
Kelford 176 t camshafts
Gsc cam bolts with titanium washer
Golden eagle cam gears
Golden eagle oem head gasket
Golden eagle lsvtec kit
ARP 2000 head studs
Speedfactory thermal intake mani gasket
Gates racing timing belt
Edelbrock victor x intake mani
Speedfactory 70 mm throttle body
SUSPENSION/BRAKES/WHEELS/TIRES
Rear disc brake swap
Scare bird rear disc conversion bracket
Moog trailing arm bushings
Energy suspension control arm bushings
Front upper and lower and rear lower
Oem ac Delco remanufactured rear calipers
high performance pads
Drilled slotted rotors front and back
True hart toe arms
True hart upper control arms with upper bal joint front and back
Progress cs2 coilovers 450/350
Timken wheel bearings front
Moog inner and outer tie rods
Moog lower ball joints
Beck and arnley e break cables
Russels ss caliper brake lines
Stash auto brake line tuck kit
Type r master cylinder and brake booster
Vms revolver 15x8 wheels
Tri state motor sport traction bar
Fuel/E85
Jb tuned 8 an feed 6 an return kit
Jb tuned oem hanger mod kit
Walboro 535 hellcat pump
I’d 2000 cc injectors
E85 freaks fuel filter
Speed factory fuel rail
Turbo/cooling
Speed trap consulting predator turbo high temp ceramic coated turbine and compressor covers
Tri state Motorsport ramhorn
Turbo smart kompact dual port 34 mm bov
Turbo smart gen v 45 mm hyper gate
Speed factory 850 hp dual back door intercooler
All fittings oil and water lines from b and r fittings
Vibrant polished aluminum 3 inch intercooler piping
Skunk 2 dual core half radiator
Turbosmart 4 port boost solenoid
Speed factory 4 bar map sensor
Ignition ECU
p28
Hondata s300 v3
Pwm kit for boost by gear
Honda rules coil on plug kit
Oem k20 coils
speed factory cop plate
Speed factory block off plate for distributor
TRANSMISSION
Gsr
M factory lsd
Carbon synchros
New bearings and seals
Drive shaft shop 5.9 axles
Competition clutch twin disc
Speed factory detent springs
civicboy07
Oct 21, 2014 05:44 AM
runs11's
Nov 4, 2011 06:45 PM
runs11's
Oct 12, 2010 11:44 AM
craiger
May 6, 2008 04:50 PM
Targa4Life
Mar 15, 2008 11:31 AM
