does anyone know how to take out the 92-95 gauge cluster?
FIRST: take out your hazard switch, (with a thin peice of somthing so it will get under the switch and not damage your cluster surround) there will be one screw underneath that. un-screw it.... unwire the swich and your clock if you have one
note: signals will not work without the hazard switch re connnected, so be aware of that
Second: take out the 2 screws that are under the top of the cluster surround (on the vynil peice abouve the center of your steering wheel)
now the cluster surround should just pop off
after that there will be 4 screws you need to take out, 2 on each side of the cluster. and it will just come out.
and there you have it, simple as that.
[Modified by Simple, 10:38 PM 11/17/2002]
[Modified by Simple, 10:39 PM 11/17/2002]
there were clips all along the bottom of the black facing part, two under the guage cluster, one to the left, and two to the right under each of the vents. it was a real PITA to get it out hte first time, but then I just broke them all out and it's been real easy since
Thank you so much...everyone, it really helps alot....
but Simple it doesn't sound simple at all.
live4soccer7
Nov 3, 2011 07:06 AM
civicdragger818
Nov 18, 2002 11:10 AM
