Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 CRV 4WD Transmission fluid type
Old Dec 12, 2021 | 03:35 AM
02BladeRider's Avatar
Default 2005 CRV 4WD Transmission fluid type
hello
my daughter bought a a 05 crv for a commuter car. the transmission fluid looks dark red and needs to be changed. what brand fluid can we use on it? is it only the Honda ATF DW-1? can we anything else?
im also going to change rear differential as well. At work we do have a transmission flush machine. maybe i will use it. also how hard is to replace transmission filter?
thanks
Old Dec 12, 2021 | 06:08 AM
Ryanthegreat1's Avatar
Default Re: 2005 CRV 4WD Transmission fluid type
There is an inline filter to the oil cooler that is easy to change but has no service interval. Then there is the internal to the transmission filter that requires splitting the transmission housing to change.
DW1 for the transmission, Dual Pump Fluid II for the rear end.
Check out Aisin fluids, they seem to be the OEM supplier but I can't confirm that.
Old Jan 27, 2024 | 12:15 PM
voodoomaster
Guest
Posts: n/a
Not that easy actually....very messy it can be.
dk199160
Oct 23, 2015 11:54 AM
LittleGuy1972
Aug 19, 2011 09:05 AM
sharpescalade
May 31, 2007 12:31 PM
businessmanph
Acura TL, RL & ZDX
Sep 8, 2006 01:57 PM
CRX MASE
22
Dec 17, 2004 05:34 PM
