LSvtec 600-700 rpm idle surging
Old Dec 6, 2021 | 12:20 PM
SlowlyProgress's Avatar
Default LSvtec 600-700 rpm idle surging
Have an LSvtec in my 2000 ek hatch
Previous information: Ive had an idle surge for as long ive had the car, and it just surges between 800-1000, but I tried to make the car idle higher by this:
I tried and tweaking my throttlebody for higher idle, and it seemed it was working great for the first 5 minutes, just to not be at 900 surging. Then, on the highway going 75-80, when i let off the gas it let off hard. Stopped to get off at a light, car idled at 500 and I thought it was gonna die. Now, i cant even drive because when I let off throttle, then just barely press back, it will throw the car back and forth really rough unless I put the clutch in.
Whats happening? And what do I do. Anything helps please.
Old Dec 6, 2021 | 10:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: LSvtec 600-700 rpm idle surging
You have altered the resting TPS value by mechanically adjusting the throttle blade stop. Your TPS voltage must be adjusted to reset it properly.
kornerk12
Nov 17, 2005 10:30 PM
Fatty_1775
Aug 6, 2003 05:32 PM
REDMAN1322
Sep 1, 2001 01:29 PM
