Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
ABS Issue
Old Dec 2, 2021 | 03:37 AM
jmath1's Avatar
Default ABS Issue
I recently had the clutch replaced and it came back with the ABS light on the dash. Diagnostic scan doesn't return any codes. I've checked the fuses under the dash and engine bay and they are fine. Any ideas what I can check next?
It's an 07 HONDA CIVIC SPORT Manual FD2 4 Door Sedan FWD PETROL 2.0 litre, K20Z2 I4 16v DOHC VTEC MPFI.
Thanks!
Old Dec 2, 2021 | 05:40 AM
Ryanthegreat1's Avatar
Default Re: ABS Issue
Make sure the brake fluid isn't low but it sounds like the scan tool you used isn't capable of reading the ABS module for codes.
Old Dec 2, 2021 | 05:50 AM
jmath1's Avatar
Thanks, I'll check the brake fluid and yeah I tried 2 different OBDII scanners I bought from eBay paired with a few different phone apps so it's very likely they are just junk so might need to take it to a professional one
condor22
Nov 23, 2021 09:43 AM
EnciuIoana
Sep 10, 2020 11:13 AM
Kirt Thelander
Sep 23, 2018 12:55 PM
s_vares
23
Apr 10, 2006 06:46 PM
eLuder
Jun 15, 2002 04:01 AM
