Anyone have an original service manual or supplemental texts for wiring on ef chassis
Just need to figure the wiring in order to convert to obd 1 but cant find the orginal service manual anywhere.
Do you know where I can find one that works? I'vebeen looking aroudn but can't find people who have used a harness for the EF.
Ugh trying hard not to troll this post
but what are you looking for?
wiring diagrams from an ef?
directions how to go obd1?
an ef engine harness?
Well I would settle for any of the latter, becasue I need to convert it to obd1 for a swap that I have planned and I could be able to if I had wiring Diagrams from the EF. I found wiring diagrams of the engine where the motor was pulled out of. I already found directions of going OBD 1 but last person who had the car made an engine swap previously and left a mess of wiring. I would also settle for en engine harness that converts to OBD1 but I havent seen any that have worked with the b20 I want to put in.
Integra type r swap calipers
Engine bay with b series in it
Switching topics, which method did you put type r calipers on your EF?
And when's the last time you got an alignment done?
theres a thread somewhere on here on doing a BBK. Long story short, DA integra front spindles, type R caliper and mounitng brackets, 2004 mini cooper base rotors IIRC. Pretty much it. recommended to toa 50-50 prop valve and larger brake booster from a prelude. I got my alignment done recently within the last month and worked perfectly with camber adjustment arms. I have -1.5 in the front and -2 in the back because its more of a canyon cruiser
I should add that I asked for the camber amount, I didnt want them straight vertical but also didnt want to chew my wheels out quick
looks clean and a really nice colour!
what is the intake tube you're using, i need to find one that clears the battery like that?
habanerored06si
Oct 10, 2012 12:14 PM
