road noise in my hatch
Old Nov 17, 2002 | 12:25 PM
ernie's Avatar
Default road noise in my hatch
When i'm in my 99 hatch, I hear alot of road noise. I was wondering if anyone can give me any ideals of where the noise might be coming from and what causes it? It comes from the back of the car, I'm guessing the wheels. It gets really loud when I increase my speed, usually 60 or above. I thought it was my shocks, so I changed them to koni's. Then I thought it was my tires, so I changed them. I needed both anyways, but they didn't stop the noise. Help, its getting annoying and I can barely hear anyone in my car!
[Modified by ernie, 9:26 PM 11/17/2002]
Old Nov 17, 2002 | 12:48 PM
Turbohatch's Avatar
New User
Default Re: road noise in my hatch (ernie)
The only thing i can think of is there might somthing stuck under your wheel well and its rubbing against your wheel. I was hearing a very loud noise coming from th back of my car, a jacked it up and found a small size bird jammed into my lower control arm rubbing against my wheel. Also check all the bolts somthing might be loose.
Old Nov 17, 2002 | 02:20 PM
splitime's Avatar
Default Re: road noise in my hatch (Turbohatch)
LOL
[Modified by splitime, 11:20 PM 11/17/2002]
Old Nov 17, 2002 | 04:22 PM
allmtrSI's Avatar
the road noise i hear mostly in my car is from the tires. . . a while back i had to slam on my brakes and because of it, there are now flat spots on the two front tires and when i am driving there is a vibration and the noise sucks!
Old Nov 17, 2002 | 04:25 PM
420aNT's Avatar
Default Re: road noise in my hatch (allmtrSI)
maybe a bad wheel bearing
Old Nov 17, 2002 | 05:34 PM
Ricey McRicerton's Avatar
Default Re: road noise in my hatch (18gTeg)
My hatchcy used to make horrible noise, but then I put the backseat back in!!! (gutted+azenis=loud as heck!!)
Old Nov 17, 2002 | 06:52 PM
jas0n's Avatar
Please don't hurt me!
Default Re: road noise in my hatch (Ricey McRicerton)
gutted my hatch noise went up
radio turned higher
Old Nov 17, 2002 | 06:57 PM
SpoonFedHatch's Avatar
your wheels may be out of balance, that will cause slight vibration and noise....umm...do you have a bent wheel---that could be a cause too.....check it out man....just jack the car up and make sure everything is gravy
refpoman
Honda Civic (2001 - 2005)
Nov 17, 2013 04:09 AM
Geoshanna
May 20, 2013 07:27 AM
k20eklipse
Aug 3, 2010 08:40 PM
NightStalker
Apr 2, 2007 05:48 AM
bokguay
Nov 25, 2002 03:11 PM
