Honda CR-V & Element 2WD & 4WD Element & CR-V
Steering Rack Play
Old Nov 28, 2021 | 12:56 PM
bumblebee009's Avatar
Icon4 Steering Rack Play
Hey all, I'm hoping I can a reply ASAP. Recently purchased a 2000 CRV from a friend. He replaced the front subframe as well as the front suspension. My issue is that my steering rack seems to have some play. When I went to test the wheel bearings, I saw that my steering rack had quite a lot of play. Found that the 2 bushings under the driver side that hold the rack in place were missing so I purchased some OEM ones to replace them. After that however, the rack still seems to have some play. I have checked the tie rods and plan to replace them too. My question for you all is, what else should I be looking at? I do also have a low mileage rack on hand in case that needs replacing but I'm running low on funds and can't seem to figure out what else I need to check. Any input is greatly appreciated! Thanks everyone.
VTEC junky
Suspension & Brakes
May 26, 2013 10:48 AM
vinuneuro
Suspension & Brakes
Nov 21, 2010 11:28 PM
Mohsin
Oct 7, 2008 01:56 PM
dr_latino999
Jun 17, 2008 09:59 AM
CivicHB93JDM
Sep 8, 2005 09:00 AM
