98 integra tach and speedo signals
What kind of signal do the factory tach and Speedometer gauges receive from the ecu? I’ve always really liked the way the factory integra gauges looked and am hoping to retain them while swapping to a Holley stand alone. TIA
thank you good sir. Does the speed come straight from the speed sensor? That tach signal I’m pretty sure can come from my holley but if I can get around having to use I/o for the Speedo that would be cool
Tachometer can also run off of the ICM signal. The tach output from the distributor is this, as is the NEP output on obd2b ecus.
the VSS pulse comes from the sensor and is “tee’d” at the brown distribution connector near the ecu under the dash.
