Dual point dpfi code 16 fix
Old Nov 27, 2021 | 11:27 AM
Efmysedan's Avatar
Default Dual point dpfi code 16 fix
I just got my red sedan running and only one code was with me code 16. I checked to see if my aux injector wires went to A1 & 3 and if the main injector wires went to A3 & 7. They did all good. Checked injector plugs ground wires continuity to ground. All good. Checked injector resistance all good. 0.3 @ 20k. Then I seen this
see how the pins on my main injector or crooked. I straitened it out. Reconnected the plugs pulled the hazard fuse to reset the ecu. Put back the hazard fuse back. started it up and the code 16 was gone.
Old Nov 28, 2021 | 08:00 AM
Marcos Barrios's Avatar
Default Re: Dual point dpfi code 16 fix
thats awsome man
i know that when you have problems like this
your mind goes everywhere
and 9 times out of 10 the fix is something like this
93LsVx
Aug 28, 2010 09:20 AM
Red_ED8
Jul 15, 2010 11:19 AM
sk8shorty012
Jun 9, 2006 02:41 PM
slywfbpsi
Jun 9, 2003 11:07 AM
typegsr
Apr 30, 2003 05:01 PM
