P0933
I have a 2008 Honda Accord coupe 2.4L. Car hesitated when starting. I turn engine off and started again. Drove home and when I stopped the engine light turn on. OBD read P0933, Crankshaft Position Sensor. Let sit overnight and checked it in the morning. Engine light was off. I check the system again. OBD read P0933 ---Crankshaft Position Sensor "A" Circuit Intermittent. After changing the CKS the car runs great. This happened again. I replaced the (CKS). twice so far and check engine light does not light up on dashboard. Has anyone had this problem? Is a relearn/reprogram of the engine control module required?
You probably mean trouble code P0339. There isn't a code P0933 for your model year.
Issue may possibly be due to a corroded ground cable. See this link: https://us.autologic.com/news/2009-h...t-interruption
joey_B
Dec 23, 2015 05:47 PM
hiforever3
May 5, 2015 08:11 PM
