Whistle/noise throttle body
Old Nov 11, 2021 | 08:05 AM
Nes@lisbon's Avatar
Default Whistle/noise throttle body
Hey guys, recently my 1990 Civic ee9 started to make a noise from the intake manifold. Taking out the admission air tube, looks like its from throttle body. Everything is stock, and dont have a clue on what to do ir be. Can some1 Help plzz.
IDdle is unstable when engine is warm, 1000/1500 rpm.. no check engine light.
Ear the noise from the vídeo.(Will upload when i convert from MP4)
The picture with the Yellow circule, its not that hole, but the 1 on top execly like that.
Not that, is the 1 execly like that on top
Old Nov 12, 2021 | 05:36 PM
1992BB2's Avatar
Default Re: Whistle/noise throttle body
I would check for a vacuum leak. They will whistle whenever you use cold air intakes sometimes as well.
Old Nov 13, 2021 | 06:29 AM
Nes@lisbon's Avatar
I Will check for leak, noise is made by the air indeed, hás i cover the top hole and noise goes, also when i put pedal 2 the metal, (air goes in) noise goes.
Old Nov 15, 2021 | 11:39 AM
Nes@lisbon's Avatar
After seaching for the origin of the noise, found out its the EACV/IACV. Gonna try to clean it to see if noise goes
civicgsr116
Nov 22, 2007 08:47 AM
rsf-g
May 9, 2007 02:22 PM
Mike17
May 8, 2004 06:06 AM
visual
Sep 1, 2003 06:38 AM
crxtreme27
Aug 31, 2002 11:49 AM
