Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
please help 01 civic 1.7 225xxx crank no start (low fuel)
Old Nov 10, 2021 | 04:51 PM
A ADKINS's Avatar
Icon4 please help 01 civic 1.7 225xxx crank no start (low fuel)
ran great with only intermittent starting problems then got worse especial if it was a warm engine, one day it stalled in a parking lot and only restarted enough to putter across the lot then no restart.
came back 2 days later started first lick then drove great all the way home. even restarted back well. 10 mins later no start.
so, I tore it down. and replaced a bunch of stuff and still no start. it will however run as long as i spray starting fluid or gas in throttle but dies unless its fed gas and some of the air is restricted by putting Ur hand over the throttle hole.
it has all new
injectors (all 4)
new fuel pump.
ect
spark plugs
cam sensor
crank sensor
battery is good
only codes are catalyst below efficiency bank 1
also cleaned grounds and then I got a p1106 BARO performance code but it cleared off and never came back. I've done a lot of fiddling with this engine hopefully it just popped up bc that and not an ecm prob. also i do not have a multimeter or other ways to test fuel and other systems besides a basic code reader, but to the best of my knowledge and investigation all relays and fuses are in working condition. I've recently been investigating the vacuum system for bad valves and such incase of fuel air ratio problems but I'm inexperienced with vacuum lines but i can run a basic smoke test using a fluid transfer pump and a stogie from gas station lol
Last edited by A ADKINS; Nov 10, 2021 at 05:06 PM. Reason: need to add more infomartion
Old Nov 12, 2021 | 06:23 AM
NDNV's Avatar
Default Re: please help 01 civic 1.7 225xxx crank no start (low fuel)
Bad main fuel relay(s)?
Senditdude
11
Jun 5, 2024 01:45 AM
OkPuddin
Honda CR-V & Element
13
Oct 9, 2018 03:44 PM
d17a2mmm
31
May 6, 2016 06:47 AM
peacelilly42
Feb 18, 2014 07:59 AM
bluecoronet
Nov 25, 2010 03:31 PM
