O2 sensor help, need smog
Old Nov 8, 2021 | 02:13 PM
mattw_hk's Avatar
Default O2 sensor help, need smog
I recently bought a 96 Del sol with the d16y7 engine. I replaced the exhaust and put a cat in it was straight piped before. The downstream o2 sensor was missing and I bought one but the wires and connector to the ecu aren’t present either and I’m not sure how to go about fixing it. Does anyone have any advice?
Old Nov 8, 2021 | 09:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: O2 sensor help, need smog
The original cat would be on the front of the D16Y7 engine... so BOTH the primary and the secondary O2 sensor plugs are found on the engine harness near the front of the engine... just below the distributor. You could run a sensor plug extension between this location and your secondary O2 sensor to make things work.
Old Nov 8, 2021 | 09:36 PM
mattw_hk's Avatar
Ahh I see. Thanks
blueknigh7
Honda Civic (2001 - 2005)
Feb 3, 2020 10:16 AM
cs1985
Mar 5, 2008 11:21 AM
240gtr
Nov 25, 2007 04:12 PM
SIK IN DA HED
Aug 10, 2004 02:55 PM
SpiceyRice
Jul 5, 2004 08:33 AM
