AC Compressor/Clutch replacement
Old Nov 7, 2021 | 08:54 PM
CKnight90's Avatar
Default AC Compressor/Clutch replacement
My ac has been slowly going out. It'd work in 85F or below weather. The clutch wouldn't spin when it was above that temp or if i sat too long with ac on. I thought it was my few month old Denso Remanned Alternator or tensioner pulley making this grinding/whinny noise. The noise got louder over time. One day I pull into home and smell a weird smell. So I let it set for a few days. I come back to it. Take off the belt and spin the alternator, spins fine. I spin the tensioner pulley, spins ok with a little jingle. Then I thought it was the tensioner pulley. Later that night I figure I better do more research about how to replace it and verify its the tensioner. I came across a video of a guy replacing his compressor. He showed the noise it was making before he replaced the clutch assembly. So the next day I went to check everything again with the belt on. As the car was running I looked below around the compressor(wheel turned to the right). I could smell that burning smell. I got up and looked above at the compressor. I use take a screw driver and try to hear/feel the vibration on the tensioner & alternator. Nothing vibrating more than usual. I go turn the ac on. I look at the compressor again and notice smoke coming from between the pulley and clutch. Should I just replace the clutch? Or just the compressor? Do you think i damaged anything else?
I also forgot to mention. Before the sound got really noticeable. I did drive through really high water one night. I'm not sure if that made things works or if the compressor got slightly submerged? Or if the compressor/clutch was on its way out anyways. It did fail give me this issue almost 2 week after though
Old Nov 11, 2021 | 07:20 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: AC Compressor/Clutch replacement
Replacing the clutch is the more economical way to go, replacing the entire compressor is the more prudent way.
Id replace the compressor assembly.
Crobran
Feb 9, 2017 12:37 PM
BayArea42
Honda CR-V & Element
Nov 12, 2016 11:45 AM
maxzoran
Nov 3, 2009 02:11 PM
b18c4door
Jul 9, 2003 05:09 AM
