88 CRX DX auto revs high before shifting gears
Old Nov 2, 2021 | 03:54 PM
GruntCaptain's Avatar
Default 88 CRX DX auto revs high before shifting gears
I just picked up a 1988 CRX DX auto with 105,000 miles. Drove it from Georgia to Tennessee with no issues (250miles). Two days later it seems to rev longer before shifting gears. I’ve only driven it in the neighborhood so it stayed in the low gears. Any help would be appreciated.
Old Nov 6, 2021 | 02:30 PM
JohanH's Avatar
5 Year Member
Default Re: 88 CRX DX auto revs high before shifting gears
Did you find an answer for this?
Mine does the same: mostly when shifting from 2nd to 3rd.
It's a 1991 auto with about 40k miles in the clock, recently changed ATF.
Strangely it doesn't always behave like this; unfortunately I have not been able to determine in which situation it does occur.
Old Nov 12, 2021 | 12:25 PM
Efmysedan's Avatar
Both of yalls trans is done. A fair price for a rebuild is $900 if you do the removal and install yourself. More if you have the shop do it all. 900 should include a rebuild and refurbished torque converter.
Old Nov 12, 2021 | 09:47 PM
JohanH's Avatar
5 Year Member
Done after 40k miles? That's amazing. Didn't realize the Honda auto boxes were that bad.
Old Nov 12, 2021 | 10:43 PM
I topped out the atf and it works like normal. I was just low on atf turns out.
Old Nov 14, 2021 | 01:29 PM
Efmysedan's Avatar
yup 40k miles or at the age of 30 years old which ever comes first
Old Nov 14, 2021 | 01:32 PM
Efmysedan's Avatar
thats good brother enjoy
Old Nov 16, 2021 | 05:51 AM
JohanH's Avatar
5 Year Member
Thanks very much for this feedback.
Mine turned out to be the same; added 0.5 ltr. ATF and all is well again
BTW it was just at the MIN mark. Would like to know how much is the difference between MIN and MAX.
Old Nov 19, 2021 | 03:25 PM
AGump96's Avatar
You might check it again just to be sure you're not losing fluid vs. it just wasn't filled to the proper level.
My drivers side axle seal had a big crack in it and all of the trans fluid drained within 24 hours.
Old Nov 25, 2021 | 09:21 AM
JohanH's Avatar
5 Year Member
Spoke too soon. After 1 day the issue popped up again.
Old Sep 30, 2022 | 04:04 AM
JohanH's Avatar
5 Year Member
Fixed mine by adjusting the throttle control cable
alupso
Sep 20, 2006 01:30 PM
DarkZachiel
Jun 2, 2004 09:47 AM
AVXHATCH
Mar 2, 2003 08:43 PM
