Civic grinding when pressing clutch after installing clutch kit
Hello. New to the forum. I recently installed a clutch kit in my 97 civic ex. The kit was easy enough to install but aligning the transmission shaft back up to put the transmission back in was a mother. Finally got it in and everything bolted up ok but the there is an awful, very loud grinding noise when i push in the clutch now. It sounds like the teeth on the flywheel are hitting something but wouldn't that occur with the clutch in or out? My noise only happens when pushing the clutch in. Thanks. Dan
