Civic starting issues
First post here and I really need some help. I've been having a major issues with my civic starting. It's a 1994 civic with a b16a2 swap. It does not want to crank or start in hot weather at all or after I let it sit after a 15+ minute drive. It is very inconsistent and I have had to push start it countless times now. When I turn the key to the second turn, I can hear my fuel pump working and when I try to start all I get is a click and no crank at all..it will not start (previous owner did a coolant fan bypass so that also turns on during the second click, sometimes it doesn't turn on at second click). My fuel pump is working fine, my main fuel relay is good and even re-soldered it just to be sure, my battery is new, I've replaced the starter, and my ignition coil looks ok. It will start in cool weather just fine (for the most part, it won't start here and there), but will not start at all in the heat or shortly after it sits after I have driven it. Some things to note: the car has an alarm system installed, has some sort of clutch pedal bypass (starts without pushing down on the clutch) and a fan bypass (which is very inconsistent and doesn't run every time on second key turn). Another note, on the second key turn it will either beep like normal or will not beep at all ( I just want to include all that just in case that narrows down the issue or interferes with anything starting related). At this point I think I'm having some sort of electrical issue and cannot get to the bottom of it. Please help, this is my daily. Thank you in advance!
ReVeNgEd-SoN
May 28, 2010 10:41 PM
