Where'd this pin come from?
Old Oct 24, 2021 | 07:08 AM
neutronscott's Avatar
Default Where'd this pin come from?
I found this near the rear of my 88 CRX after replacing the gas tank. Definitely didn't punch any out...
Old Oct 24, 2021 | 07:25 AM
Ryanthegreat1's Avatar
Default Re: Where'd this pin come from?
That looks like the shift linkage pin at the transmission.
Maybe it was some road debris that fell out when you dropped the tank? Or maybe it was on top of the tank from the factory as an extra.
Old Oct 24, 2021 | 10:13 AM
Tyson's Avatar
Shift linkage pin.
Doubt it just fell out. Worth a look. Tranny side of the linkage.
Old Oct 24, 2021 | 11:46 AM
I should've taken the pic with the linkage pin. I took that out last night. This pin is smaller diameter. Thought maybe something around fuel pump or two-way valve area use a pin?
Old Oct 24, 2021 | 11:52 AM
Here is comparison. Bitch pin on top. Unknown on bottom.
Old Oct 24, 2021 | 11:03 PM
Tyson's Avatar
shrug. then its just a roll pin.
bitch pin is the only roll pin i know of.
Old Oct 25, 2021 | 05:20 AM
91zSi's Avatar
Believe it's from the rear plastic storage component's hinge.
Old Oct 25, 2021 | 09:14 AM
That does seem reasonable. I searched Honda parts for other roll pins and only saw transmission and possibly glove box. Thanks!
Old Oct 25, 2021 | 08:47 PM
I confirmed it fits the personal trunk and there's still one missing. Good enough. Thanks again.
Pin, Spring (6X30) - Honda (94305-60302)
vw eater
Nov 2, 2008 08:55 AM
BoostedEF
Oct 9, 2008 11:29 AM
coldtotouch
13
Aug 29, 2005 09:46 PM
PGT Driver
Sep 27, 2004 09:03 AM
Mr Boston
Apr 20, 2003 12:09 AM
