Honda CR-V & Element 2WD & 4WD Element & CR-V
2012 CR-V Snow Chains
Old Oct 23, 2021 | 08:56 PM
crv967's Avatar
Default 2012 CR-V Snow Chains
Hello everyone! I’m new to the forum and I’m looking to buy snow chains for my 2012 CR-V. I don’t live anywhere particularly snowy, but I do plan to take frequent trips into the mountains to go skiing, where they require chains often. I’ve been reading my owner’s manual and it talks about using S class cable radial chain SC1042 chains. In my research, I’ve read that Z type chains are better than radial. Does it make a difference if I were to get Z type vs radial type? It seems to me that it doesn’t matter as long as they are S class. Am I correct in that? I don’t know much about snow chains, as I’ve never had to use them before. Thanks in advance!
Old Oct 24, 2021 | 07:36 AM
Ryanthegreat1's Avatar
Default Re: 2012 CR-V Snow Chains
Studless snow tires and AWD are typically fine in place of chains. At least around here that is the law. Far less hassle than chains and safer.
You should be fine with Z bar chains. Just make sure they have a proper fit and are installed correctly.
2dr CRX
Aug 3, 2014 09:52 AM
PePpeRedDc5
Mar 2, 2005 03:54 PM
ReVtecSi
Acura TSX
Feb 13, 2004 02:57 AM
ITRSpeed
Feb 9, 2004 05:26 PM
AURSX-S
Aug 9, 2002 10:58 AM
