H22A4 Block using K24A2/K24Z3/TSX RL5 Pistons
Hey what's up everyone, I'm new to this forum and in need of of knowledge, so I'm rebuilding my H22A4 and my pockets don't allow for me to get Forged Pistons, I've been doing some research & need clarification on using Nippon Racing Full Floating 87MM K24A2/K24Z3/TSX RL5 Piston Set. Will these Work for my Daily H2B set up? I'm not looking for High HP just a nice Daily H2B rather than having my SOHC Vtec Die on me LOL, Plus Running the SOHC with A/C the car is waaaay to Sluggish, i got the motor for Dirt cheap and Engine was Smoking a bit & Owner dint want to Overhaul the Virgin, So I had the Head Cleaned up @ Machine Shop & installed new Valve Stem Seals, The Block was Decked, Crank Micro Polished, And FRM cannot be honed plus Machinist said Cylinder Walls where mint (Thank GOD lol). When tearing the Block apart we noticed that Piston #3's had a broken piece being held up by the Ring Landing which was due to BAD Maintenance & Cheap Oil. Can i Use the Nippon Racing Full Floating 87MM K24A2/K24Z3/TSX RL5 Piston Set on my Block ALL INFO will be much appreciated & i will keep you guys posted on my build. Thank You Very Much & may God Bless You All.
Ryhaz
10
Jan 14, 2014 07:57 AM
m R g S r
Apr 23, 2004 04:46 PM
