Starter only works outside the car.
Old Oct 13, 2021 | 03:37 PM
L8Apxr's Avatar
Default Starter only works outside the car.
Starter wouldnt crank the engine. So i took it out and got it tested, and it tests good. I reinstalled it, and it will not crank. I hear the solenoid working, but the motor wont spin.
Any guesses?
SOLVED: It needed an additional ground. Once i ran another ground from solenoid housing to firewall it cranked the motor beautifully.
Old Oct 14, 2021 | 05:51 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Starter only works outside the car.
Have you tried to manually turn the motor at the crank with a socket and breaker bar? Maybe the engine is seized.
Old Oct 15, 2021 | 05:58 PM
L8Apxr's Avatar
I have a short circuit somewhere. When i connect the battery directly to the starter it spins the motor like a champ.
Now if i only knew where.... /sigh
Old Oct 23, 2021 | 06:37 AM
XrayBravoGolf's Avatar
TomCat39 probably meant try turning the engine instead of the starter?
Old Oct 23, 2021 | 03:17 PM
L8Apxr's Avatar
engine spins freely. Thx.
An extra ground wire solved this problem, by the way.
Old Oct 25, 2021 | 08:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You never provided the year or specifics of your car. I know the 92-95 civics had 2 major grounds in the engine bay besides G101 which was ECU dizzy ground. There is a major ground from frame rail to transmission, then another ground from upper rad support to Power Steering bracket on the pull side. If either of those were missing, the car will have issues cranking and starting.
Glad you got it figured out.
ProfMore
Oct 11, 2017 06:29 PM
Hectorzg1
Jul 28, 2010 08:03 PM
JDMB20TDA
Oct 2, 2008 08:38 PM
97LXAcc0rd
Sep 28, 2005 11:18 AM
jared3
10
Apr 9, 2002 11:38 PM
