Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
8th gen civic - first time wheel bearing and hub replacement
Old Oct 12, 2021 | 04:03 PM
Honda-Civic-Runner's Avatar
5 Year Member
Loved
Default 8th gen civic - first time wheel bearing and hub replacement
Im going to be doing a front and rear wheel bearing and hub replacement for the first time ever. im seeking advice as a first timer.
i have a few questions and anyone who could help me would be great.
  1. i seen that one can use a wheel bearing removal toolkit to thread in the bearing using a cup mechanism. When its time for me to push in the bearing, how deep must i go?.. Would i be turning the tool til it stops turning all together? what if i push in too deep.. is there a way to extract it a bit back out.
  2. the rear seems easy. Would all i require is to remove the 4 threads from the hub and bearing assembly and just insert the new one and reattach the new assembly? any specific things i should be aware of.
Thanks for your help!
Old Oct 12, 2021 | 04:41 PM
Ryanthegreat1's Avatar
Default Re: 8th gen civic - first time wheel bearing and hub replacement
A large impact gun is going to be your friend.
Bearing presses in until it stops. Don't forget the bearing is directional. The ABS encoder goes to the inside. Typically this is the rubber dust shield side. The metal shield goes out towards the brake rotor.
Old Oct 12, 2021 | 05:03 PM
5 Year Member
Loved
thanks chief, very helpful. Yes i have a large impact gun and wrench. should be able to get those nuts off. and yeah i almost forgot about that abs encoded part.
kwae
Honda CR-V & Element
Mar 13, 2016 08:35 PM
papa-g
12
Mar 16, 2010 12:16 PM
z6hatchboy
Feb 6, 2009 06:31 PM
lowtegsr
Jan 31, 2008 04:30 PM
ryanstev
Dec 30, 2007 01:31 AM
