Temp gauge pegs out
Old Oct 10, 2021 | 11:39 PM
easymoney903's Avatar
Premium Member
Default Temp gauge pegs out
First off I’m not sure which yr or model this instrument cluster came out of. I has a tach on the left and the temp and fuel gauge are on the right. If I plug in the original(has no tach) everything works correctly. When i plug in the swap the temp gauge go to max scale and stays there. I was originally thinking the voltage connections were reversed from unit to unit. Is it possible i need a different sending unit? It has a d16y7 under the hood right now so not sure which sending unit it it has.
Old Oct 11, 2021 | 09:30 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Temp gauge pegs out
If the temp gauge works fine on your stock gauge cluster, but doesn't work properly with the replacement EX/Si type gauge cluster, it sounds like the temp gauge in the replacement gauge cluster is bad. The sending units are the same and do not need to be changed when using different gauge clusters. Try another gauge cluster.
dglassmyer
Apr 27, 2010 08:14 PM
xsicrx120
Sep 23, 2009 02:00 PM
Tech-Nics
Jun 30, 2006 07:45 PM
pK1spooled
13
Sep 27, 2004 03:01 PM
BigIslandBoi
Sep 26, 2003 03:48 PM
