Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic 2004 oil lamp display
Old Oct 8, 2021 | 06:59 AM
myx's Avatar
myx
Default Civic 2004 oil lamp display
Hi Guys,
Hope all r doing well. This is my first post here. I have an Honda civc 2004 vti which is displaying oil lamp warning on dash, after 10 secs of starting the car the warning light goes off. I checked with a garage and told me the oil pressure switch is faulty. I hope someone can suggest which color is the switch is it green or black ended ?. Thanks in advance.
Old Oct 8, 2021 | 07:07 AM
Ryanthegreat1's Avatar
Default Re: Civic 2004 oil lamp display
Does it have oil in the pan?
Could be the switch, could be lack of maintenance, could be a failing oil pump, could be sludge build up.
Putting a pressure gauge on it and going through the steps to reproduce the issue will be the best method.
Old Oct 8, 2021 | 07:33 AM
myx's Avatar
myx
Hi Ryan,
Thanks for replying. Yeah oil is there already checked, I was asked to replace the faulty switch, having checked online i am confused about the color of the switch, I dont know much about cars. As this is my first car, I would like to buy the right part, also the parts are no longer available even from junkyard. Thats my dilemma.
Old Oct 8, 2021 | 07:39 AM
If the vti is the 1.7 then either of these part numbers should fit. 37240-PT0-014 or 37240-PT0-023 both are readily available in the US.
Old Oct 9, 2021 | 11:05 AM
myx's Avatar
myx
Yes it is vti 1.7, thanks for the part nos Ryan.
Old Oct 12, 2021 | 06:21 AM
NDNV's Avatar
Before replacing the oil pressure switch, you should check the oil pressure to see if the oil pump is failing or you have a clogged screen. Then again if the mechanic has tested the oil pressure switch and deemed it faulty - replace it.
Jose Holguin
Sep 8, 2017 06:47 PM
emendez23
Aug 25, 2013 05:19 PM
Laceyfer
Jun 27, 2012 03:56 AM
team 15
11
May 24, 2010 12:53 PM
SleepyHF
Mar 16, 2004 06:40 PM
