Are civic and del sol radiator hoses cross compatible?
Old Oct 3, 2021 | 05:49 PM
NiftyJake's Avatar
Default Are civic and del sol radiator hoses cross compatible?
Are the radiator hoses in these 2 listings interchangeable? I was going to buy just the rad hoses and do the vacuum lines separate but I think it would end up being cheaper to get them all at once. My question is, are hatchback and del sol radiator hoses the same shape, and are they routed the same? Because if they are the same I'm going to order the ones that include the vacuum hoses. I couldn't find a listing that has the vacuum lines included that specifically says "del sol" within it.
Civic hoses
Del Sol hoses
thanks in advance guys, I've been in the Honda game for a while now but I don't usually browse these forums just because sometimes people can be toxic.
It's a d16z6 si motor swapped into a 1995 del sol S. Everything was done correctly and under the hood it is a complete SI.
Old Oct 3, 2021 | 09:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Are civic and del sol radiator hoses cross compatible?
As long as your Del Sol has a SOHC engine installed, then the upper and lower radiator hoses, as well as the radiator, will be very similar to those from an EG ('92-95) Civic Hatchback.
ForgetMyNameX07
Nov 7, 2008 06:29 AM
punkybrewster
Apr 18, 2006 07:44 PM
the soL that could
12
Mar 25, 2006 03:58 AM
JMinSi2000
Jan 7, 2005 10:44 AM
