Oil leak near/under EGR (02 Accord 3.0)
Old Sep 30, 2021 | 07:36 PM
evanbcasey's Avatar
Icon4 Oil leak near/under EGR (02 Accord 3.0)
Hey guys, new here. So I noticed a puddle (small) of oil in a crevice underneath/beside the EGR valve. I was thinking maybe a leak from a bad gasket cover. I cleaned it up and drove it for an hour, came back, and no leak (Note: I did not engage VTEC during that drive). So I went back out and engaged VTEC off and on for about 15 minutes.... and sure enough, there were oil deposits in the same place. Thoughts? Obviously, it's coming from that VTEC variable timing solenoid, or so I would presume, however, I figured id ask you folks here. Thanks in advance.
-Evan
Old Oct 1, 2021 | 07:28 PM
Steve Massey's Avatar
Default Re: Oil leak near/under EGR (02 Accord 3.0)
The only places that could possibly be leaking in that area are valve cover gasket, vtec solenoid gasket, or distributor.
Old Oct 3, 2021 | 02:11 AM
evanbcasey's Avatar
Thanks Steve . Had it planned to look at the Byrd solenoid today … but that was before the rubber inside the spark plug socket came off and is stuck down on my plug. Will do that walk of shame to Walmart later to grab a metal coat hanger…. Then I WILL fix whatever leak is going on
2pac1
Jan 13, 2019 06:51 PM
Spike_irl
Dec 3, 2014 07:25 PM
wgbm92
Dec 30, 2012 10:26 AM
jdm ek9 101
May 10, 2007 11:30 AM
hybrid1990crx
Aug 12, 2005 10:41 AM
