Help with headlight conversion 94 Del Sol VTEC
So I've got 4 HID Bulbs for the headlights. 2 are in and work fine, but I cant find the plugs for the other 2. They're independent right? What do I do next?
If its unclear, each bulb has its own plug. In my defense, I found it like this. I cant find another set of wires for the 2 loose bulbs. The ones working now i think are stock. Theyve got a red/green, red/yellow, and black wire
The H4 bulb that is found in the Del Sol headlight assemblies is a Hi/Lo bulb... they are not separate. The wire colors that you have described above confirm this. I don't know why you have 4 HID bulbs, but if you have two already installed, you likely are already done and just don't know it.
Theres room for 4 bulbs, so if I stopped here there'd be 2 empty sockets. I think the housing is JDM. The US ones have the headlights and blinker housings seperate right? Its just one assembly here
rockstarcolin
30
Jun 5, 2009 04:22 PM
