The wiring from the harness connector's terminal side is:
1 - IG (IGN01) from junction connector (power)
2 - PG (Coil) from ground G101
3 - IGN01 from PCM
This would match with the way you listed for the ignition coil.
Thank you for the response. I found a diagram for them, which coincides with what you've said. However, it does not match the way I listed. Regardless, both you and the service manual have provided the proper wiring.
