Toda B owners
Old Nov 17, 2002 | 09:32 AM
jdmb18c's Avatar
Default Toda B owners
What are your cam gears set at. I'm trying to see if there is a common set up or if it is different for each setup.
Old Nov 17, 2002 | 09:33 AM
Dave-ROR's Avatar
Default Re: Toda B owners (jdmb18c)
different. get it tuned. and get your fuel fine-tuned more. are you running an EMS or a VAFC?
Old Nov 17, 2002 | 09:45 AM
jdmb18c's Avatar
Default Re: Toda B owners (Dave-ROR)
I am running hondata and have done lots of tuning. The reason I'm asking is because my setup made peek power with exh set at 0 and a .5 degree advance on the int. cam. there was no major changes throughout the powerband.
Old Nov 17, 2002 | 11:18 AM
Blade's Avatar
New User
Set cam timing according to the tech sheet that comes with the cams. You need a degree wheel and dial gauge.
Old Nov 18, 2002 | 04:01 PM
jdmb18c's Avatar
Default Re: Toda B owners (Blade)
here must be some more Toda B owners out there. Please help.
Old Nov 18, 2002 | 04:11 PM
xjohnx's Avatar
That is a little unusual, but not unheard of, Most people experience the most gains by advancing the hell out of the intake cam, i have heard of at least one other case where it made the most power at 0 though, so you're .5 degree advance isn't unheard of.
Old Nov 18, 2002 | 04:12 PM
Hooch'n's Avatar
Default Re: Toda B owners (xjohnx)
dyno tune those bitches!
Old Nov 18, 2002 | 04:19 PM
Rob :190:'s Avatar
Default Re: Toda B owners (Hooch at 8400-RPM)
with someone who knows what the hell they're doing.......
Old Nov 18, 2002 | 05:16 PM
jdmb18c's Avatar
Default Re: Toda B owners (Rob :190:)
Once the new mods are done (over the winter) I will have to tune it again. I tried many different combinations last tuning session, and will try them again in the spring. I have an excellent tuner as our shop is an otherized Hondata dealer (only one east of Montreal in Canada) and we have unlimited use of a Dyno Jet. I'll just have to see what happens in the spring. Thanks for your imput and more is welcome.
Old Nov 19, 2002 | 06:17 AM
Black R's Avatar
25 Year Member
.....it varies according to mods, displacement, compression, etc.
I'd suggest advancing the intake,and retarding the exhaust...
I made the most power from +15, -5... but your setup - even the exact same motor might make the best power elsewhere... This is after tuning the fuel, btw...
Old Nov 19, 2002 | 06:28 AM
CHEETAH's Avatar
i've seen it range from 1/2 of 1 cam degree to about 12 cam degrees after degreeing. although those are outliers, the typical range is around 4-5 sepration. ensure your t-belt is not off by 1 tooth. It could be possible to have that settign if you have a stock header
just degree them, get a moroso kit or make your own degreeing kit.
greg
Old Nov 19, 2002 | 06:15 PM
jdmb18c's Avatar
Default Re: Toda B owners (CHEETAH)
Thanks I'll make sure that when we install the new toda belt its not off. Buy the way I 'm using the DC JDM header.
Flux
Nov 27, 2007 03:42 PM
Spoonson
Jun 15, 2007 08:08 AM
alfaaay
Feb 13, 2005 06:23 AM
