Stock Temperature gauge is a tick above half
That depends on what the actual temperature is. If you have a stock ECU, you can plug in an OBD-2 diagnostic tool and monitor the Engine Coolant Temperature in real time as you warm up the car... if the temp at idle stays between 193 and 203* F, then your needle is simply moved upward slightly. Temperatures above 211* F will make the needle climb quickly toward HOT, so you may actually be running hotter than you think.
I have always used a aftermarket coolant gauge with the sender on the top hose. The factory needle has only ever moved above half way when I had a coolant leak and at that point it shot up to the red fairly quickly.
Okay.. to test whether is it overheating or not i have driven the car for like a few hours non stop but it seems fine .
and the cluster is modified plug in and out with some other cluster fuel temp plate and speedo as well
i guess i am fine
i guess i am fine
If your cluster is modified, then maybe something is wrong with it. You can get one of those thermometers that lets you point a beam towards an object. Point it at the radiator and engine and see if your engine is too hot or not.
