Is the throttle body gasket suppose to be....
you should, i guess it just depends how often you take it off. If it looks real bad, replace it, if not i guess it should be OK.
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
it helps to do it, especially if it's wet. once it's wet it won't be very good anymore. same goes with the sensor gaskets (if you touched those)
I got a CEL light (code 7 tps sensor) and tried to see what the problem was. I took the car to the dealer and they found that the wires were coroded. Weird.
Peter Langly
Jun 18, 2004 03:19 PM
