H23a will crank but won't start
So my H2B swapped hatch has been sitting a few years now. About two months ago I got it started it cranked and started right away. I lost the keys and put in a new ignition cylinder lock and its cranking but won't start. Compression on all cylinders is around 180-185. I'm getting spark and put brand new spark plugs. I'm getting fuel but not sure if they are making it past injectors. I'll check the injectors next but I'm pretty lost on what else can be wrong with it. It's been sitting in a field so is it possible a mouse could've damaged part of the harness or maybe the ECU is bad? Any help would be greatly appreciated.
boostedcivichatchbacksi
Jul 22, 2004 11:39 AM
