Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car dies all of a sudden while driving
Old Sep 14, 2021 | 02:18 PM
jvmagic's Avatar
Icon5 Car dies all of a sudden while driving
Hi,
My 05' Civic (1.7) started to all of a sudden die while driving (very intimidating) and there is no CEL. The car will start up after I put in Park and turn over after it has died. It does not do this when the car is cold meaning for the first 15 minutes of driving or so. When driving for 20+ minutes, it can randomly die while car in in D and I'm driving normal.
I read that it could be a loose ignition switch but I tested as stated (car on in P and move the key) and it does not cause the car to stall/die.
Anything else I can look for?
Thanks in advance
Old Sep 15, 2021 | 05:18 AM
NDNV's Avatar
Default Re: Car dies all of a sudden while driving
Check timing and the main fuel relays behind the glovebox.
Old Sep 15, 2021 | 11:07 AM
jvmagic's Avatar
Do I replace them both or can they be tested?
Old Sep 16, 2021 | 06:38 AM
NDNV's Avatar
They can be tested for continuity first before deciding to replace them.
Old Sep 22, 2021 | 05:29 PM
benchwarmer's Avatar
5 Year Member
Test the alternator while running , you should have 14+ volts .
Old Oct 4, 2021 | 09:57 AM
jvmagic's Avatar
The alternator tested ok.
Switched the two fuses as stated but the car still dies (maybe a bit better; takes longer period of time before the car dies).
FLiPFeLLaH
Sep 16, 2012 04:57 PM
civicb16eg
13
Dec 16, 2007 09:08 PM
richi3seg6
Dec 6, 2005 08:41 AM
Sohc Driver
Jul 9, 2003 06:15 AM
